This command displays VLAN Authorization information for a port or list of ports.
port | Show VLAN Authorization information for a specific set of ports. |
port_list | Specifies the list of ports to show VLAN Authorization information for. |
If no parameters are specified, all VLAN Authorization configuration information is displayed.
None.
This example shows how to display VLAN Authorization configuration information for ports 1:1-3:
# show policy vlanauthorization port 1-3 VLAN Authorization Global Status: ENABLED Admin Oper Port Status Egress Egress VLAN ID ========================================= 1 enabled untagged untagged none 2 enabled untagged untagged none 3 enabled untagged untagged none
This command was first available in ExtremeXOS 16.1.
